Wires…may or not be the problem, but any experienced ‘tech’ will tell you that if everything is original, to do cap/wires/rotor and plugs (if not done before) at the same time.
Motor is deff going, ill give you 300 cash tonight
lmao, get em
I had a dizzy go bad in less than 10k miles… Dizzyking free replacement ftw
Try to replace the coil ,besides just the cap and rotor. I just replaced the rotor and cap and it didnt do jack. I just bought a used dizzy on honda-tech for 50 .00 shipped. I had this problem under boost. So in the spring I am just replacing the whole thing.
wet the car down with water at the wires if they arc replace em if not dont .wires arent part of a tune up if your carefull and dont swing off of them esp imports .that bein said sounds like a tune up condition to me replace the plugs and use dielectric grease on em " the porcelin " lolol if it still does it most likely the dist is bad .is the c.e.l flashin at ya at all ?
600 and we got a deal! I fixed it up alot!
Cell doesnt flash…but its been on sense I bought it! not sure what the codes are…as I have never owned a obd1 car before.
what were your symptoms when yours went bad??
thinking about going to a junk yard to get one.
Different than yours. My tach needle jumped like crazy above vtec. I also had one off eBay that caused similar problems to yours. That’s when I went with the distributor king one and fixed most of the issues.
its the ignitor/coil inside the dizzy. at load your not getting a higher more powerful spark, causing a missfire
what about a TPS sensor??
400, deal!.. be there tomorrow.
im selling it in spring! not now lol
In spring I want to get a 4.6l Jeep Lorado.
cars fixed
you were all wrong.
New cap and rotor later, all it needed was new plug wires.
Wow go figure! A Chevy guy knows more about fixing Hondas than the Honda guys!! :rofl
eh. it could have been a number of things that needed to be replaced. normally, when i get a higher-miled honda i replace:
plugs
cap
rotor
wires
fuel filter
air filter
pcv
oil change / transmission oil change
yup, we all got great info and the chance to look it over too:ponder
motor is still going…300 cash
:facepalm FML! I’ve never once ever had to put wires on a Honda. :ponder FML. Glad you got it fixed though man!
Diagnosing cars over the internet sucks ass!
