Need help to fix windsheild washer
both my water sprayer is not workin…i dun know wats wrong wif it ??..i am guessin i have to change them …or i dun know…wat to do ??..
anyone can give a suggest or give me a hand to fix them for a free dinner ???
thx
would help if people knew where you live.
but uhm if the squirts dont work check some things.
double check if theres fluid.
make sure the hose that goes from the body/firewall to the hood is hooked up
listen for the washerfluid motor while its on, they are usually pretty loud and can be heard easily outside of the car.
get a buddy to squirt the squirters and see if the liquid come out anywhere if the squirter motor is making noise.
if the fluid is full and you can hear the motor working, chances are the lines are frozen (need to use winter fluid) or the nozzles are clogged.
check the fuse
I’m going to go with plugs are rotten right off the pumps and useless.
common in S13’s… seen it 2-3 times on my cars…
well my car is a hatch, the back one still sprays, the front one wouldnt, the pump is b/s’ed and untill friday…pay day… i just took the hose off the bottom that goes to the back, and switched it with the one that goes to the front, now when i hit my back window spray button it comes out on the front window…ghetto fabbing but it works to help with broke times
if you switch the harness on the back on the motors then it will work normally and you rear button and pump will just not work
