S14 washer squirters
Is the motor for the squirters and the resivoir one unit? anything i can check before replacing that? my wipers work but nothiing happens when i try and squirt fluid.
thanks
You can jump the pin on the connector to see if it makes a noise. I am not sure the colour of the switched power that goes to the motor but a little trial and error you could figure it out.
there are only 2 wires. Just put one + and one - and you should hear the pump.
doesn’t matter which way you jump it, the pump will just go in reverse.
or get a test light, hold down the nozzle spray, and test the wiring.
for my s14 the wires had broken off the plug.
