ok my dash cd player and security are not working any ideas why
any details…lol
well the car starts any everything but the speedo,dash lights,cd player are not turning on
Get a checker, look at the harness, all of them are connected in parallel for the power after I belive the firewall, split the cord at beginning of harness? Power? If yes then follow your harness to the devices and find out where power is being lost.
If being lost before the split in the harness; it will either be a fuse or potentially the power going to the fuse itself.
Good Luck.
would it be the fu100a ?
Get a tester, or a battery with and LED and test ALL your fuses.
You will be glad you did
Everything was working on my car, I had some burnt out fuses, replaced them. Did it do anything? Who knows. But atleast it all works now.
fixed it thanks
Hey i got the same problem you find out what it was ???
