I got a problem with my 91 240sx (coupe).
Car starts and runs for 5 minutes and then stalls out. I checked the fuses and it keeps blowing my 15 amp Fuel Pump fuse.
Any suggestions on why it keeps blowing the fuse?
Thanks
Aleks
Thanks
Aleks
check the wiring on the sending unit.
i say check the ground going to the pump
Too much current draw from the fuel pump, or corroded wiring harness is pretty common. (+1 Fastback240)
happened to me in my coupe as well. ended up being the sending unit connections on the top. +2 for sending unit. I drilled a hole in the top of the sending unit and ran the wires through that then sealed it up with rtv.
i say check the wire for the ground for the fuel pump inside the sending unit
post whore.
Cool! Thanks guys! I had i feeling it was the sending unit. I’ll check the sending unit tomorrow.
