ok i was going to put on my rims and one of the nuts decided that it didnt want to come off. the stud is just spinning in the hub. i cant think of any ideas other than just cuting the nut and stud off and i dont have a problem doing that but i was wondering, is there any easier way to get the nut off so i can take the wheel off and replace the stud and does this mean that my hub is in some way fucked now because of the stud turning freely and will have to be replaced?
mine had that problem to.
but i just kept turning it till it came off.
and i took out the stud.cuz it was all loose and wouldnt let me put the nut back on.
and i still need to find replacment ones. lol
im rollin on 3 nuts. :axe: :axe:
Hammer the stud out. If you can’t aim put a nut on it for more surface area.
To install, put the stud in, put a bit of a larger nut on as a spacer, then the correct-sized lug nut and impact that sucker in until the head of the stud comes flush with the hub.
