what kind of oil do you use and how many miles do you go before changing?
i heard moble 1 was good but for newer cars becouse it is thinner is that true
i have been running royal purple 5w30 for a bout 12k
my first use i ran it about 5300 miles before i did it.
second time i ran it about 4500 miles on it. when i did this change the oil still looked purple and clean
when i ranned 5w30 syn. valvoline the trucks indicator would come on around 3800 miles
both times that i ran the royal purple it didnt come on. and this indicator some how moniters
the way the oil is broken down. { in the manual it says under the right sircumstances you can
go a full year without changing oil if driven properly, but GM doesnt recomend this. for those
that dont believe me look it up in the manuals.]
run mobil one and change it every 3K
i use 10w30 in the summer and 5w30 in the winter. thats it. i use to run AMZOIL that shit is awesome. i saw some articles of truckers not changing oil for like 40000 miles and it still passing the test that they have for oil quality
i run 10w30 mobile 1 in the camaro and go 3500 miles between oil changes
the beater gets penzoil 10w30 every 3000 miles
it has 200,000 miles on the motor and still going
I run Motorcraft or Mobile 1 10w 30 and change @ 2000 miles
or once a month.
royalpurple 15/50 every 25 1/4 miles runs!!
Originally posted by Pewterss
royalpurple 15/50 every 25 1/4 miles runs!!![]()
:bsflag: :bluez28:
Originally posted by snowhitegolf95
what kind of oil do you use and how many miles do you go before changing?i heard moble 1 was good but for newer cars becouse it is thinner is that true
mobil 1 every 3000 in the TA
the CRX wolfs head brand when i rememeber:D
Originally posted by Shaggy
:bsflag: :bluez28:
:jerkit: :asshole
DSM’s dont take oil… they run on yuengling and testosterone.
and PURE LUCK everytime
5w30 castrol GTX synthetic every 4k miles. I’m thinking of using royal purple. How much does that cost per case?
Valvoline SynPower Full synthetic every 4-5K miles
around 4 or 5 bucks a qt!
thats not bad. i’ve heard a lot of good things about it.
ill be selling it shortly!!
i’ll need a case in about 2 months:D
mobil 1 every 5-6 k. No need to change it any sooner than that.
snow- you know ron changes his oil every 25k with mobil 1.
:eek:
i know but im confused
hell with it. dont change the oil, in fact take 4 quarts out. VR6 motor swap would be justified then for sure.
