93 S13, stock KA24DE. Car was parked for a few weeks, it was started less than a week ago, worked fine. I had to change the waterpump today as I was visiting Toronto, the car wouldn’t start. I boosted the battery, it cranks fine, no problem, just won’t catch.
Fuel pump primes, you can feel fuel flowing through the return line, but can’t feel flow in feed line (coming out of the fuel filter). Wtf?
Took out spark plug, connected it to wire, touched end of spark plug to strut tower bolt/valve cover, no spark. Cleaned distrubutor rotor and cap since they had a lot of residue on them from the coolant being flung all over the engine bay by the waterpump. Still no spark.
Left plug out of the cylinder, cranked multiple times, no fuel mist sprays out of the head. Another wtf moment. Fuel pump is a brand new walbro installed a couple of months months ago.
Any ideas guys? It mysteriously started for like half a second once, but I was outside of the car turning the key, couldn’t get on the throttle in time. It was after squeezing the fuel lines in weird manners. lol
Fuel filter was replaced last year. And yes, there is some gas in the tank, probably about 3 weeks old I’d say. I had a jug of gasoline lying around in a storage container from like 2 months ago. I put a litre or 2 into the tank. No difference.
Possible culprits:
Bad ignition coil, bad rotor/dist. cap, big vacuum leak, plugged fuel filter, bad timing, malfunctioning FPR…???
