Hey guys, my car oringinally had power locks but when I bought it they weren’t working. The old owner said it might be a loose connection or something, so I took apart my door, and here are the pics.
1st pic: The wire that is connected to the locks (i think) was cut and a new one was wired there (no idea why)
2nd pic: The wire runs though the door…
3rd pic: The wire comes out the door where it’s opened and closed, and jsut ends there…
Now, what do I do with it? WHere is it supposed to run to ??
I’m guessing its suppose dto go through the hole in the car to the place where all the wires are (pic below) and connect somewhere there but I couldnt find any loose connections?
Any ideas on how to fix it? ANy ideas on why it was cut?
Thanks.
Those are not factory locks those are aftermarket door lock actuators and look to be terribly installed.
Does the car have an alarm?
If your car doesn’t have an alarm, I suggest getting one cause the installer will most likely fix this problem for you
No, the car doesn’t have an alarm. It used to, as can be noted by random wiring as well as that little light that flashes (it’s installed in the car but not connected). No idea why the alarm was removed and the wiring was so hacked up
Adam what’s so bad about the actuators? Are stock ones better? Should I do anything ot these ones?
Ken, that’s good to know and I do want to get my alarm in the future but I had plans to do it myself so I could learn how it all works. And don’t the locks have to be working BEFORE the alarm goes in anyways?
plz guys help me teh fix, i’m driving with my door apart and i want ot put it back together asap, is it really hard to fix ?
