looking for some help/advice on whether or not my water pump is dead
S13 Redtop SR20
The motor runs fine and the pullies spin freely with no noises.
The top rad hose gets hot but the lower rad hose stays cool. I also turn on the heat and fan but the air comes out cool. I started off by swapping the thermostat with a G20 thermo as it was the only one I could find on a Sunday (please let me know if this does not work). I have run the motor with the colant topped off and did the normal procedure to bleed the colant but same story… could it be the water pump or a big air pocket?
I plan to pull the water pump next but won’t be able to right away, so just looking for some help/advice.
Let me know what you guys think, thanks
