Problem with clutch pedal
yep the teggy
ok so no leaks from master cylinder in the firewall
no leaks from slave cylinder either…but when I go pump the clutch pedal, it leaks like teenage girl’s vagina
still no pressure in the clutch pedal
Doh, so you did break two unrelated things at once.
so I did broke the slave cylinder…damn it!
well I got a new slave cylinder in…no more leaks
now I need another person to help me with the bleeding part
bleeding is done…I still got no pressure
well?
what about the throwout bearing?
I gave up and started the car on fire
update
definitely is not the clutch slave or master cylinder…the problem is inside the tranny
could this be the throw-out bearing or the clutch itself?? I doubt is the clutch, that mofo is made out of steel
update
well it trun out the problem was with the shift fork
I > *. /ego
not only that
but weeks ago when I put the tranny back in, It was very hard to shift into 1st and 2nd gear, almost impossible.
wow… lots of bad luck with your car.
