So I’ve been holding of on making a build thread until I was closer to having everything. After the posting the sneak peek picture, it was clear people wanted me to start this thread now so I will.
The car as it sits:
1990 Nissan 240SX
KA24E
112,xxx
Current mods(as if it matters):
Cone filter
Apex’i Turbo Timer
Apex’i NOIR cat back
17" Tenzo RS5’s
Theres a picture of the car before the exhaust and rims.
And the exhaust.
Theres a video clip of the exhaust.
The car moves pretty well for the mods, but it was clear to me I need to do more. It just wasn’t fast enough to cure my need for speed. So now I’m at a point in the road where I got some choices to make. I could go the typical route just like everyone else and install an SR20DET. But I’m not one to just try and fit into a crowd. Now true the SR20DET does have some pros but it also has some cons, which lead me to my motor choice, CA18DET. I know the CA18DET doesn’t have the after market as some of the other Nissan motors, but the pros of that motor to me, out way the cons of it. Before I get people jumping down my back, I did research the CA18DET, SR20DET, RB26DETT, VG30DETT and of course, the KA-T.
So what are my plans for the car as of right now, this coming summer and past that. My original goals can’t be met as quickly as I wanted because of money but they will be.
When the car comes out in spring time, it will be a CA swapped 240 on the stock turbo. I’m going to push the stock turbo to the limits and see if I can’t break some records in the mean time, HP and quarter mile. The car will also from the outside appear almost stock. I want it to be sneaky.
Around the middle of summer, the car will get a few upgrades, which I’ll get to later to make my overall goal of 300 whp. I want it to be reliable and drivable at the same time.
Past that, the car will get some visual mods, and some safety mods, but thats to far off in the future.
So what parts do I have for my spring time goal?
-Yonaka Intercooler Type 6 18x9x2.5"
-Synapse BOV (recircing)
-Apex’i GT down pipe
-Greddy turbo outlet
-3" test pipe, TBD
-Walbro 255lbh fuel pump
-Synapse FPR
-Apex’i SAFC 2
-NISMO motor and transmission mounts
-ACT 6 puck clutch with xtreme pressure plate
-DEFi Blue Racer boost gauge
-Hallman boost controller
(pics at end, if not pictured, its on order)
I have a good majority of those parts. I’m sure there is something I’m forgetting.
I will also be doing some weight reduction. What am I expecting? 190-200 whp and a weight of 2500lbs. I’m hoping with some good driving skills to push the car into the 13’s on the stock turbo.
Sometime around midsummer I’ll be upgrading to GT2871r to be fueled by some RC 550cc injectors which will in turn be controlled by Apex’i PowerFC. Along with that will come some more gauges and who knows what else. That will push me to my 300 whp goal with ease. What am I expecting from this setup? I’m not really sure. I thought I knew how fast it would run, but I think my original guesses were quite a bit higher then they probably should have. But I got some time before that happens, so we’ll have to wait and see.
That about sums it up for where I am now, and whats on the way.
