How easy is it to convert and automatic 96 240sx se to manual. I know it is possible but will it be just like a stock standard 240 or will there be some differences. Has anyone on here done it? Thanks guys.
It’s not that easy but you can do it in an afternoon if you have all the right parts, there will be some differences between a factory 5 speed 240 and a auto to manual swapped one, and some people on here have done it.
Everything you ever wanted to know about the swap here:
S13 KADE tranny,
would that fit on a S14 KADE?
Are the bell housing the same?
Thanks.
John
yes they are, but you’ll be missng a sensor if u put it on an s14, but it’s a sensor which u don’t need
^^^ Yep, on the s13 tranny there are only 3 sensors, s14 has 4 on the tranny.
what sensor would it be missing?
Neutral
Reverse
5th Gear…
