rb no spark/fuel
this is what happened…cruisin to work n the timing belt idler pulley bolt sheared off threw the belt have since retimed,checked it a hundred times its perfect i have swapped out ecu ignitor chip,n the cam angle sensor,i even bought a newmain harness from wiring specialties cause mine was hacked n stilll no adamn spark or fuel for that matter plugs are dry,has anyone had this problem im lost now,an its nice out n i have no whip
have you checked if your valves seal anymore? The rb’s are interference motors and usualy mess up bad if they throw a timing belt.
I could turn the cams over no problem gonna do a comp test today.but that doesnt help the no spark or fuel issue…an the motor shutdown as soon as it happened i was stopped on an off ramp not buzzing it out to 9
check efi relays/fuses first, are the injectors getting 12v ?
i have checked both n yes they are i can make them pulse with the cas,what i need is someone to come over have a couple n make this slut run i will pay labour too,this problem is beyond my knowledge
check compression, if you have no compression, send me a personal message and well work a deal out.
