ok i recently changed my agx shocks to coilovers… the coilvoers are set slightly lower height then the agx lower springs…
nothing is rubbing in terms of tire/rims/multilink/coilover/exhaust…
after i installed the rear coilovers i now HEAR scraping sound from the rear… it sounds like the brake pads are rubbing the rotor ALOT of something… but when i jacked it up i can still spin the wheel freely by hand…so the pads are floating not pressured
… i have no idea what is that sound and what the problem is… any ideas?
hey season, remember i had that problem at last yrs fall 240 meet? it ended up being my rotors were having too much play, because the rim i put on were not sitting on the hub correctly. check your rotors if they move back and fourth, and check if your lug nuts are tight.
