Rebuild kits....
What do you guys think about this rebuild kit?
" Our Import Engine Rebuild Kits maintain the same high quality standard found in our domestic kits. They feature parts and components from TopLine, an industry leader in import engine parts. Import kits are supplied with a Overhaul Gasket Set , Piston Rings, Main Bearings, Connecting Rod Bearings and Thrust Washers where applicable. Piston rings and bearings are available in your choice of sizes at no extra cost. "
$340 (probably USD)
Here’s the link… http://www.hi-performance.com/ImportRebuildKits.htm#Nissan4Cylinder
Please note that all prices shown on this web site are in Canadian dollars.
says so right on the homepage
sounds like a great deal
Except that if your rebuilding, would you not also want to change all the timing chain components? Given their history I personally would…
Just a thought.
