I got this clean titled 95 Eagle Talon TSi September of last year and drove it for a bit. Been thinking about selling it. I need to clean out my toys and use the money elsewhere. The car just turned 83,000 miles and is a 5-Speed. I have done a lot of the usual maintenance myself. Here is what was replaced:
-Brand New Fuzion HRi tires (4) have literally 200 miles on them
-Timing Belt, Water Pump
-Replaced the clutch with ACT 2100, flywheel machined correctly
-Front wheel bearing and axle
-Fuel pump re-wire
-Bosch o2 sensor
-Valve Cover gasket
-NGK plugs
-Fuel Filter
-Added an Autometer Boost Gauge
-Currently runing a K&N Cone filter kit
This car drives beautiful. Rides smooth. Motor is strong, turbo spools nicely, no loud valve ticking, doesnt leak fluids, regular oil changes, ect. THE TRANSMISSION IS BASICALLY PERFECT. No grinds, nice crisp shifts. The exterior is pretty good. COLD AIR CONDITIONING. There are some light scratches around the car, maybe a couple really small dings. The front bumper has scrapes on the very bottom and some paint chips on the front. Interior is very nice, pretty clean, no smells.
The price is set at $5500 obo
Here is proof of the wheel bearing, axle, and clutch work that I did:
i’m not sure if that was sarcastic or not since it is hard to tell online, but i was serious, if you have a price range you’re looking to get let us/me know and i’ll tell you if I want it
That is a great price for that car if its as clean as you say. OBD I too. You should try to get more for it. I think you could. I paid $6100 for my '97 with 98K on the clock.
