Ok so for a long time my car wouldnt run just a little sputter and nothing more so i let it sit for about 2 monts. So the other day i just tried for the hell of it to start it and it actually started to my surprise it was running fine let it run for bout ten or so min so it would warm up at that point i went to move it so i gave it a little gas i reved it up to about 4000 rpm no big deal so the rpms drop and it just shuts off so im like wtf??? now it wont start again it just cranks and cranks with a little sputter every once and a while just like before. I know i have good fuel pressure so that i know is not the problem.
Vehicle
95 Passat
Motor VR6 about 200*** miles.
Any help is greatly appreciated
Thank you
check ign. coil??
also check the plugs and wires.
Donno but thats what i had problems with.
ok i was thinking it was the coil i know its not plugs and wires cause they are fresh. thank you
how did we confirm fuel pressure?
there is a little screw on the fuel rail that i made a gauge fit to and not only that but it floods after cranking for a while.
