sr smokes at idle and high revs sometimes
So I’ve been having this problem ever since i went to a thicker oil this one time and accidentally overfilled the motor oil. Causing the engine to burn it off.
Since then I’ve done 2 oil changes. And my car smokes a little at idle sometimes, and the last couple track events i had this season, i was told my car burned oil around the track.
Now, i don’t have that catch can thingy that comes stock with sr’s, could that be the only issue. Or am i looking at a serious problem. Like head gasket or leaking valve seals or something?
Could the pcv valve just be fucked, and I need a new one?
You need a compression test. That will tell you a lot.
as for your pcv valve, unscrew it. While it is running at idle, there should be a hissing sound going through it. This is vacuum from the manifold. This is telling you its not clogged.
or, take off the pcv valve and shake it. if the check valve is bouncing around in there, its fine.
Make sure your using a high performance synthetic, shitty oils will break down easier causing it to smoke.
perhaps your turbo is fudged and ur oil is burning there, coming out your exhaust
always run mobil1 synthetic, 10w30- it works the best for sr20s.
I would still put my money on your turbo, cuz its very rare that sr20s consume oil.
Have you got any oil in the fmic pipes ? exhaust ?
I’ve got a little coat of oil in the exhaust.
I’ve also been hearing some weird noises from the exhaust side of the engine, for couple months. Very slight but its there. Its so quiet, that i can’t determine if its the turbo or what. But today when is started the car, i could hear some background noise outta the exhaust pipes. I m thinking my turbo is fucked up. It sounded like a whoosing sound.
What you guys think?
I m gonna do a compression test this weekend.
id say turbo then…probably the bearing noise, or the fins hitting sidewalls…
comp test is easy, come by and ill do it for ya.
mmm, maybe a cheap turbo upgrade is in store.
Car is parked in garage man.
cheap and turbo should not be used in same sentence
u have a power fc, now get a turbo and have some fun !
gt2871, life will be good. i promise…well after the like 1200-1400 price hit lol :slight_smile: get the turbo.
lol. gt2871r is some crazy shit. I was thinking of running maybe a ball bearing t-28.
Gonna look into it. Since i already have power fc, just need some injectors and turbo and lines n shit. ahah. Better start selling my parts off.
do it man, i was never more happier in my life when i got that gt2871r. shits legit. keep your stock manifold tho lol. and get the .64!!!
if your feeling crazy grab a head gasket/headstuds…i cant remember if you have a fmic. you can push 350whp all day.
lol. Yea i got a fmic. Only thing holding me back though, is the increased cost of tires. ahah.
What kind of tire life you get outta something nice like a 235-255 federal in the rear, with your power? I know those normal tires you run only last u like 5-8 laps.
Depends on your definition of cheap.
check your turbo. i always ran 5w40 in my sr felt way better with the thinner oil.
dont overlook the pcv valve like you said… besides its cheap so change that while ur at it…and look into a catch can
Yea i’ve been slacking on looking at the car, as its cold as shit in garage. But I plan on running a catch can in the summer and replacing the catchcan. I m gonna do a compression test sometime this week to make sure its not the engine block itself.
Hopefully its just the turbo.
