whats up, just finished my sr swap, used a fmic, but theres no provisions to hook up the boost pressure line, im wondering if anybody knows somewhere else i can branch into to hook it up, without having to weld on a ‘bung’ for the hose to go on, motor is s13 redtop btw
thanks people!
t of the intake mani somewhere
Do you actually mean the Boost Pressure Solenoid or the Waste Gate Actuator ? If it is indeed the Solenoid then don’t even bother as you don’t need it and I didn’t even know people bother to hook them up.
Hey codyne you’re combining two things there… it’s the wastegate actuator which is a solenoid and the boost pressure sensor.
You can use the ones coming from the TB and the other to the intake pipe.
i welded a bung on my hotpipe and used a nipple to screw the wastegate actuator line.
you did the swap already? holy moly
cool prob solved got a couple small other issues but im gonna start a new thread so it says in the title lol, thanks ppl!
