sr20 swap problem the remix
so i got my engine in and it running great now after i fixed a few grounds and switched the ecu but now i have no clutch I bled the shit out of it like for an hour and nothing. I switched the slave cylinder and re bled them and there is like alittle bit of preasure right at the bottom of the pedal but theres like 4 inchs of free play … i tryed to ajust the free play but it can only ajust the wrong way. so i donno like should i just keep bleeding it or is there somthing that is wrong with this picture …
could also be your clutch master cylinder…
Remove the damper box. It it attached to the passenger side frame rail. Then bend the metal line to it connects directly to the rubber line going to the slave.
Then keep bleeding.
his clutch dampener has already been removed
look for air bubbles coming out of the master cylinder just incase to see if it is bad or not
