My front driver side shock is touching the wheel, ie the spring seat is resting on the inner edge of the tire. The car also pulls heavily to the left if i let go of the steering wheel,
i’m thinking its the ball joint but i’m not sure. Any ideas of what could be the problem?
well if the rim and tire sizes are stock and it is rubbing… you have big problems… check to see that the spring is sitting in its seat properly. remove the rim and check everything out… make sure all the bolts are in the suspension properly.
the spring seat should never touch the tires if you have stock wheels and tires on because the bottom of the shock has a bracket that’s bolted to the upright where your hub for the wheel sits…
so, you should definitely check out the lower control arm, the balljoint, and how the upright is sitting on that balljoint.
My car is an 89 hb, also the passenger side is fine and the 2 front tires are the same size. The spring seat on the shock is touching the top of the tire(the tread) and not on the wall.
Problem has been fixed. It turns out the balljoint was not the issue, it was the spring hat, there was play in the mount. So i just swapped the shock assembly from my parts car and now theres no more rubbing.
