ok. I installed sleepy eyes in my car I now I have just noticed that when I start my car I have this ticking sound coming from under the dash, it sounds like if you have your hazards on but not exactly, it is a little bit slower paced, I don’t know if it has anything to do with the sleepy eyes, but I don’t recall having it before I installed them.
thanx
will
Gonad
April 9, 2004, 11:34am
2
You installed sleepy eyes? What’s that supposed to mean?
Do you mean the Pivot controller or did you simply cut the green (or
brown?) wire on the headlight popup button and put a switch in between?
Uniac
April 9, 2004, 2:02pm
3
sounds like you have yourself a bad relay, Locate the faulty relay and replace it.
Gonad, were you wondering if the brown wire works or if he used it?
Gonad
April 9, 2004, 3:54pm
4
Nope. I did the sleepy eye already, just forgot which wire I cut (green or
brown - or something else all together).
I know there’s a diagram on NICO or one of the other forums. Just gotta search.
Uniac
April 9, 2004, 5:51pm
6
brown works too, we’ve had this argument before.
actually, I hooked it up through the fuse box under the hood and ran a couple switches inside the car, if that helps
My way gets the job done, and my relays still work so hush down Jesse.
Anyways dude, just listen around for which relay is clicking and figure it
out, then you can trace the problem.
