usually the weight doesn’t come into factor, the fact that you are towing a wall behind you that is the problem.
if you have an open trailer you will be fine.
I have an older f150 that I tow my car on. the trailer is a race car trailer with a huge tire rack right in the front (not aerodynamic at all) and I’ve never had a problem.
but then again I have a newer escape that completely fucked the transmission by pulling a closed trailer.
i plan on towing it with a ford ranger, 4x4, auto tranny. Its rated at about 5000lbs. And yeah i was planning on getting an open trailer, because i would be renting one or borrowing one most likely.
yeah, i’m sure it’s not as good as say a fullsize, but it should work fine if that’s what it’s rated for. i’m hoping you have the 6 cyl. and not the 4 though…
i tow a 10,000 pound enclosed with my yukon, its only rated at 7500
no issues ,
i wouldn’t worry about the weight, just toung weight, position car on trailer nicely!, and it will be a breeze, being a open trailer the wind resistance is very low,
^ yea i got a 09, with a 4.0L. its got a 3.73 gear lsd. Its already got a class 3 tow thing on the back, which is rated at 5000lbs, so i think i m good there.
The tranny cooler is something i’ll look into. As drive to shannonville is 3 hrs. I probably would FLOOR the cayuga hill way before the gas station hits and time it with the lights. Hills are no problem.
the drive there isn’t that bad its the drive home that sucks ha. ive got a 3.0l auto ranger and i don’t think i would ever tow my car with it, well i don’t think IT ever could. Plus ive already had to put a tranny in mine ha
