im draining my manual tranny oil, and tha drain plug is a b!tch to take off. any special tools or different method to take it off? or to drain it? i need it drained asap, as my engine is coming out soon and this is basically one of the last steps to take my engine out!
hopfully your not in the same situation that im in, i guess the person that had my car before tryed to impact gun it off and semi stripped it. so now i cant take the fucken plugg off. only way i can change fluids is to take the tranny out and drain it that way. sucks :evil:
jack the front end of the car up, and take the driveshaft out, it’ll drain out the rear fo the tranny. Not the best way to solve the problem, but better than pulling the tranny.
well i put some penatrating fluid on, dont wanna stripp it. it was close to so i stopped. only one edge is bent in. hopefully i can get it out tmr soo my engine can come out. thnx for tha quick reply guys.
I’m pretty sure they’re made out of aluminum.[/quote]
owned.[/quote]
I owned myself I guess. I had the same problem this weekend with the drain bolt on the rear end. It actually is steel, I just thought they were aluminum since I never really noticed any rust or anything on them and the fact that they seem to be as soft as aluminum and strip so easily. My mistake, weld away!
