I was just wondering if you could help me out. I’m trying to pull my tranny out (93 FB). I’ve got all the major stuff done, just gotta disconnect the tranny from the driveshaft.
I can disconnect the 6 bolts before this (towards the front of the car) where teh propeller shaft is…this is where teh FSM tells you to disconnect the driveshaft…is it safe to disconnect here? I looked at the FSM regarding disconnecting here and they said I need a plug…and not to mess around with the rubber stuff…should I just go ahead and disconnect at this spot? It looks like the easiest option… Any suggestions on getting those 4 bolts off?
Also a handheld torch (used carefully!) can be very usefull in breaking stubborn nuts free. Get them nice and red hot at least and then give it a try, I had to do it on my Auto drive shaft during my 5spd swap because they were on there like a son of a b****h. No match for a torch
wouldn’t heating them make them harder to remove since when adding heat energy to the metal, it expands, exerting an even greater force on the walls of the hole, requiring more torque and therefore effort in order to remove it? (unless it heats up to the point where the metal becomes soft and you damage the threads). i don’t get how that works. :-k
From what I understood when we did it, the nut and the bolt or treaded stud are essentialy partialy fused together from either rust, corrosion whatever it may be, the heating causes the metal to expand. The two metals are not going to expand the same (you try to make the nut heat up not just heat it all up). Since the flame is hitting the nut it will expand at a greater rate then the stud. This is where you then remove the nut, key is not the heat things up to the point where tread damage can take place. My dad showed me it while helping with my car I was impressed by it (he designs engines and was a patternmaker) so I am preaty sure he knew what he was doing.
