So as 99% of you know, my TT swap was hell, and is still hell, more as of today…and i’ve been meaning to do a write up on my experiences with Z1Motorsports.com (a “highly respected,” well known, big time distributor for new used and oem parts for the 300zx na and tt, 350z, and g35) for a while now, so here it is…
i was recommended to them a while ago, and since then, many horror stories have come about regarding their products, and i happened to be one of those horror stories.
Before purchasing anything from them, i did a shit load of homework and knew everything i would need just about, and went to them because they carried everything i needed, new aftermarket and OEM and used…i figured buying from them all at once, they would cut me a deal, and they did…they knocked about 200 or so off of my final price…and were also willing to take an additional 400 off of the price because i had no use for the auto tranny coming with the clip, so i told them i would sell it back to them…alright, nice guys, right? WRONG!
they assured me ahead of time and all of their motors, including JDM motors, are compression tested, run for hours, and leakdown tested…
they also told me that they have on average 60k miles on the motor or so…
we get the engine weeks later than expected due to problems with their shipping company, only to find this:
bone dry coolant lines, mostly full of debris and rust…so it couldnt have been run or leakdown tested…
cut…not broken, not torn, but cleanly cut, injector plugs…also proving it could not have been run, or at least not well and with all cylinders firing…
the engine harness was TRASH, i had to get a new one later down the road, another $365…and this is what finally got the engine running right, or as right as it could…6 months into the project…
one of the intercoolers had a hole in it, they sent a newer, in good shape used one with the engine, and they did tell me ahead of time that one had a hole and that the clip was coming with a newer intercooler, but still, if they ran the car, everything wouldnt have checked out ok with boost leaking out like a mofo from that huge hole in the intercooler, about the size of a quarter…
newman did a compression test before the motor was in, and i just did one today, and the motor is beat to shit…
no milky oil, so it’s unlikely that it’s a head gasket…but damn were the numbers off…
i only got 4 of the cylinders done before i got too cold (no indoor garage space to work) and began to run out of light…but what i did read was about 120 to 125 psi for cylinders 1, 3, and 2…and about 102 psi for cylinder 5…4 and 6 i didnt even get to, nor did i care at that point…
i talked to a friend with a tt zx and he said his motor was good with between 145 and 150psi across the board…
i really dont know what i’m gonna do, at this point i can not get rid of the car, i have too much into it, and can not afford to cut my losses, if i do put it up for sale, i will not get enough back for this car to buy myself something i can use for a few years ,and it wont be for at least 5 years that i will be able to afford a new vehicle, i live paycheck to paycheck working part time, and i’m in the midst of my 3rd of 7 years i will be attending at canisius college…which is expensive enough on it’s own…
i was planning just pulling the motor and working with my cousins and friends on doing a rebuild, but when every cylinder is significantly low, i really dont know where to start or what to do…and i really dont want to have to get another motor and be the next chino, even though i think i already am…
but i think that pretty much concludes my rant, Newman i’m sure will voice in his beef with all that went down too…
FUCK YOU Z1MOTORSPORTS.COM!!!
/ rant…
