I know this sounds like a dumb question, but if the windshield washer fluid ain’t coming out the nozzles. It’s the pump (or whatever) that needs to be right? I’ve checked and it’s not frozen, and when I do try the wipers do move, just nothin coming out of the nozzles.
Is there anything I can check…
And does anyone have a rough idea on how much it’ll cost…
If you can’t then check voltage going to the pump.
If you can hear the pump going then maybe it is your nozzles that are clogged. Take a pin to the nozzles or pop them off and run compressed air through em.
BTW, you did check you fluid levels, right? :roll:
Haha…yah, that was the first thing I thought it was. Topped it up, and still nada. I’m pretty sure I don’t hear the pump going, but I’ll guess I’ll check again in a quiet place.
