So this is whats happening now :(.
So after waiting for new lines, i finally get them today.
I take the mani and turbo off once again…and all the other lil shit thats in its way.
I install the new lines, i didnt use teflon tape but i used a sealer, similar to locktight. i tightned everything pretty good.
Get all the stuff back on, start the car and oil is coming out the bottom. oops i forgot to attach the oil return line, car was idling for 15 secs before i noticed. Figured the engine is fine as it was very little oil.
Attach that back up.
Start the car, Idle is good, but as the car gets warmer i see smoke from down by the turbo i figure its just burning some shit off from when i worked on it. After prob 2 mins its still smoking (not to heavy but noticeably)
I immediately look at where the line feeding water attaches to the turbo, as this was my last problem, i dont see it leaking…
i then turned the car off, left it for an hour. started it and after warming up just a little it started smoking again. looked for leaks, nothing. looked under the car nothing.
Reved the engine a little hoping water would spray down there, nothing. Car makes boost.
left for a couple hours tried it again, and still its smoking this time i let her idle for 5 mins approx. Steady smoke, doesnt increase with revs.
Is it burning off the oil, from when it was leaking. is it burning the sealer i was using.
Would this stuff burn for that long?? im affriad to let it idle for to long or even drive her
Im getting frustrated and about to put her away early.
