my bottem end is pretty much assembled, i am debating on witch head to use, either an ls head, or gsr head? hmm a fully ported ls head doesent flow as good as an ls head, any input before i make a decide? i have em both so it doesent really matter
depends on your compression. making it an LS VTEC will probably bump your compression a little high for that 60-1. Id stick with the LS head unless you are going for a serious race motor and wanna build a super bullet proof LS VTEC. What comp. pistons did you put in? I personnaly dont think LS VTEC and a turbo go together unless its a super high hp goal.
they are like 8.3:1 weisco pistons, i am on stock sleeves and i would like to make some high numbers, im going to decide by the end of the week and hopefully get something together
Go down to HD and talk to Dennis, he has a fully built LS head for a good price that will make some serious power, or just stick with your head and get the approiate cams. At that compression an LS/VTEC would be a waste in my opinion.
I have seen 628whp on stock sleeves but that is beside the point. they are on true vtec b series motors not LS vtecs with piston speeds that are insane
Get a GSR water pump at least then if you wanna rev it that far. what “big numbers” are you looking for? Remember that the GSR is the least flowing VTEC head, so if flow is that important then you might wanna take that into consideration.
