I know this question might be a bit dumb but lol…does driving with 2 stock rims on the back and 2 17’s on the front effect the cars handling or steering at all…i guess what im
trying to say is, is this bad for the car?
It’s not bad for the car at all. You likely have a lower profile tirer on the 17s so the overal wheel diameter should be similar. It’s not AWD so it doesn’t matter.
So your front end is higher than the rear?
Nope…like deathby240 said they are basically the same size i put a stock rim beside my rim and they are just about the same
if their the same diameter which you already know they are and more or less the same width then you’d be fine…
fronts are a bit wider…but w.e drove with it today and its fine thanks!
