wiper problem
i did a search on this and didn’t find any posts regarding the problem i have,
for some reason when i press the button to make the wipers go it makes this horrible squealing squeeking sound and the wipers dont go all the way up… about 25% then goes back down… in a laggy motion…
what could the problem be??
also, could someone aid me in terms of how to install new wiper arms??
btw, this is regarding the front wipers… thanks…
someone please help me asap, i can’t drive when its raining/snowing… (OBVIOUSLY!)
someone pls help me out…
check wiper motor…
if they are not going all the way up the motor is not turning fully.
Or check for a seal from motor to wiper linkage and they may slip causing not to turn all the way
the actual base of the wiper on the front passenger side… isn’t even there…
how do i fix that?
what do you mean by the BASE?
your wiper assembly is missing or the linkage that makes it move it’s missing?
yeah, the linkage that makes the wiper move… thats what i meant by the base of the wiper arm…
so what do i do??
the wiper itself where the rubber piece that cleans your window is attached to a linkage.
That linkage goes to the point O where it bolts down. UNderneath that there is another linkage that connects wiper to motor.
that’s what i am asking you.
Which one is broken?
broken: the part where the linkage on the wiper attaches to the motor…
Can you get a picture?
Your best bet would be to just replace the missing part then and see if it works, if not then you will have to replace your wiper motor as well.
Make sure all the connections are solid though before you replace the wiper motor. (wiper arm connected properly to pivoting part… w/e it’s called that makes the wiper move)
Hey
Almost same shit happened to me.
(my wipers just stopped working completely… my motor is fine as you can hear it when you turn “on” the wipers but the wipers themselves didnt move… anyways)
Well you have to remove the wiper blades then the plastic cover under them (the long piece in front of the windshield) and check which wiper linkage arm is broken.
Then just go to a Nissan Dealership… they cost 19.95 a piece… they order it for u within 2 days. Get it and install it.
Update us on the situation
Lata
