(… and after the motor is at operating temp, obviously.)
I know I read somewhere in a manual that you can press the ‘MAX’ button (or some other button) after the vehicle is off and heat will blow into the cabin for up to 15 minutes. But now I can’t find that info anywhere.
:gotme:
I know I didn’t make this up, but I can’t find the exact instructions to know if I’m pressing the right button. Anyone know? I tried twice by pressing the ‘MAX’ button and air blows into the cabin, but it’s not that warm…
yeah you kind of have to have an electric waterpump to circulate the coolant through the block to the heater core as the heater core cools really fast when no additional hot coolant is circulated through it while the fan is blowing air across it.
maybe it has a pump but its broken?
maybe the system is supposed to use convection or it just doesnt perform as expected.
If you car has a MAX button on the HVAC panel…it will do the same thing. It stands for RESIDUAL…meaning…after the car has warmed up to operating temps…and the ambient temp (outdoors) is 59F or below…you can press the REST button (or MAX) button and warmed air will blow into the cabin when the ignition is turned off.
This is a way to keep the car warmed if you have to stop at a railroad crossing…or make small short trips to the store or bank etc…you can hit the REST or MAX button after turning the ignition off while you run in to take care of your business.
offhand I would say complexity/integration into the regular HVAC system and cost, possibly size since it would have to be somewhat large and most likely would be under the dash
This has nothing to do with an electronic water pump all it is doing is running the hvac blower after the car is off at “full heat” blowing warm air off the heater core into the cabin. My e39 does it as well.
Interesting - my e39 has an electronic water pump on the fan shroud along with the mechanical water pump on the block. I didn’t check to see if the electric pump has a seperate circuit to the heater core.
there is no way the heater core would provide heat for very long without hot coolant going through it. my accord uses a hot water valve to control interior temp and if you shut the valve off (put it to cold) it instantly loses any heat…
Uh.
take a car without this feature, turn it off, then turn the key to ON… without starting it.
so that the heater fan blows.
it will be warm for about 2 seconds.
then blow ice cold air.
becaaauussee the coolant in the heater core has been chilled?
or i don’t know.
but that’s why i thought it gets cold
and it can’t really move…
