Hey, so I failed my etest today… Limit Reading
HC 64 82
CO%.35 .61
NO 0485 3052
Two days ago it failed. So today, I mixed 2 jugs of methyl hydrate from Canadian Tire (bout 8L) into half a tank of gas. Mixed it at the etest place and let it idle for bout 5 minutes. It did significantly worse on everything besides curb idle. Also, I asked Nissan Avenue (closest to me) if they could give me a form declaring the car as a hot rod. They had no idea what I was talking about… LOL
What should I do?
Take it to a place that actually knows their shit? Most etest guys now know what an SR20 is in a 240. Talk to Re_Amemyia, he has a Crappy tire that does it.
High NOx is a result of all the methyl hydrate you put in. It makes for a hotter burn(over 2300 degrees), which in-turn creates oxides of nitrogen (NOx).
Also, get rid of the remaining methyl hydrate fast. That stuff rots out fuel lines when left for a period of time.
so I went to Dixie Nissan today… they are friggin AWESOME!!!
The guy took a loook under the hood and said “this is definetely not a ka.” wrote the paper no questions asked and best of all it was FREEEEE!!!
wish me luck on the etest
for the paper declaring my car was a hotrod? i was charged nothing. went to service desk. all i needed was ownership and the guy just needed to see under the hood. took bout ten minutes.
Anyone that knows its not the original motor should have e-tested it as a hotrod. If its a Japanese car (RHD) You get it tested under the gray market category.
I just got my car e-tested about a month ago at CDN Tire in brampton with big injectors big tubro…you ge tthe rest o the mix…the shop smelt so bad they had to evac it. It passed with flying colors.
I simply went there and said my car is from japan, the vin is shorter and there is no “Values” Set from the government or whomever says whats pass or fail. So you end up getting ridiculously high limits. Again, this is only if your car is foreign …(from outside of canada…possibly the us also)
