Update:
I’ve spent the last few hours piecing together my power steering lines. I was really trying to keep the cost down but it’s nearly impossible with AN fittings. My setup is going to completely replace all of the stock lines, fittings & cooler.
I’ll post a list of the items to hopefully help the next nub trying to accomplish the same
Steering rack fittings:
-6AN to 16mmx1.5 male w/ O-ring
http://www.summitracing.com/parts/rus-648060
-6AN to 14mmx1.5 male w/ O-ring
http://www.summitracing.com/parts/rus-648070
P/S pump fittings:
Power Steering Pump -10 AN Inlet Fitting
KRC Power Steering 21200000 : KRC Power Steering Pump -10 AN Inlet Fitting
-6AN to 18mmx1.5 male w/ O-ring outlet (replaces internal restrictor, long & ugly joint and banjo bolt)
http://www.summitracing.com/parts/rus-670531
High pressure hose from P/S outlet to steering rack:
High pressure stainless steel braided hose (3 feet)
http://www.summitracing.com/parts/rus-632600
-6AN Hose end to Female -6AN, 90° (x2) for the above ^ hose
http://www.summitracing.com/parts/rus-620421
Feed hose from reservoir to P/S pump:
-10AN Hose end to Female -10AN, 90° for reservoir outlet
http://www.summitracing.com/parts/sum-220087b
-10AN Hose end to Female -10AN, 45° for P/S pump inlet
http://www.summitracing.com/parts/sum-220086b
-10AN stainless steel braided hose (already had some laying around)
Reservoir:
Speedway Motors P/S reservoir tank w/ -6AN inlet and -10AN outlet
Speedway Vertical Steering Reservoir Tanks - Speedway Motors, America’s Oldest Speed Shop
Oil Cooler:
Derale Performance Compact Fluid Cooler, 4 row w/ -6AN inlet/outlet
http://www.summitracing.com/parts/der-13309
Hope this helps someone, because I just spent like 30 minutes typing this shit out haha
