My car was wayyyyyyyyy overfilled by whoever the previous owner was. Like 2+ inches past the full mark.
I have not noticed any driveability problems, and have never had any experience with over-filled oil. It’s VERY clean oil, so I know that it is newer and fresh.
Should I be getting my ass under the car and draining some out, or should I just leave it. Is there any risk of damage from overfilled oil?
overfilling it could have blown out some seals, but either way i wouldn’t keep driving around no it like that , gotta drain it eventually… you’ll probably be ok tho
At least someone put the right answer here, basically the crank with cause the oil to “froth” leading to inadequate lubrication, which will cause a lot of friction issues and premature wear to all rotating parts
really look on the backside of the dipstick where the marking are not… but just picture the marking on the same spot on the backside…that will give you the best reading
