get an idea of what everyones running and how they like it and how they have tested it. or what they will expect of it
footworks: 8/6 coilovers usuailly on the stiffest dampening, aluminum subframe bushings, adjustable rear upper control arms, adjustable toe rods, adjustable traction rods, energy suspension tc rods, engergy suspension swaybar endlinks, hicas rear sway bar, non hicas subframe, rear strut bar, hicas steering rack.
My steering is stiff and responsive and everyone i have ever let drive my car loves it.
my suspension setup has a lot of small bounce shitty dampening from coilovers and shitty coilovers, when compared to other higher end coilovers these have a lot of a swaying bounce eg, after hitting a bump the front end floats up and down, when i compare it to other coilovers the front end hits and is stiff with no bounce.
I installed the non hicas subframe with multi link parts and bushings all at once, I noticed the car felt a lot more “flat” a lot of the rear bounce was taken away i think the thing that makes the most difference in my setup in the rear was the bushings, seem like a very good upgrade for $100.
interior: basically only performance i have in my interior is a momo monte carlo and a short shifter.
I highly recomend gettting a wheel, gave me the clearance i need so my knees dont rub on the wheel and i can see my gauges a lot clearer.
electronics: oldschool safc, turbo timer, hud
not much to say, safc is good, turbo timer is handy, i rarely look at the hud
engine:stock ca18det, stock ar trim ca turbine, full 3 inch exhuast.
its crazy the difference you get from opening up the exhuast i went from making full boost at 4,500 to full boost at about 3 grand.
estimate my setup being about 160-170ish at the wheels might be a little more.
overall, my car needs some minor mods like dual rad fans and a fmic, tires and laser alignment and corner weighted and balanced
should make my car compeditive on the track.
ok someone elses turn.
