Alright…so my clutch has been letting out higher and higher over the past 3 months, and tonight I had some severe white smoke behind me under acceleration. I know white smoke can be headgasket, but I was more or less wondering if it could be linked to the tranny in some way?
I’ll give that a shot in the morning, I wanted to try that one tonight but its too wet out and I’d get sideways :lol
R3vlimited is pointing me to random headgasket failure or smoking due purely to the weather, and its a 50/50 split either way it seems. The clutch needs to be replaced soon but apparently transmission fluid won’t smoke white which I thought it could, so that doesn’t seem to be as immediate now.
its high moisture content in the exh just burning oout man . get the car hot and a good long trip it will be fine man . the temps are colder and a ton of water in the air so your just noticing it moreso now than ya did before
Was this, car was great this morning once I got it up to speed. I drove it home at 30 the whole way last night so I could see the car not warming up right.
Also, did the clutch trick, clutch held fine and didn’t slip.
Apparently it can be just an e30 thing when it gets cold, I’ll probably do a compression test and a bunch of other shit to the car before I head to GA. Make sure its not gonna break down in my 1000 mile drive :lol
Try to do a burnout. If you can then the clutch is good. If you break something else while attempting this, then that sucks. You would have to smoke the fuckkkk outta the clutch for it to smoke enough for you to see
Before I finally realize that the firewall in the Z was flexing when pressing the clutch (Was originally automatic no mounting holes under the steering colum for support, did not know this at the time) I kept having to adjust it, was confused, then one day tried to do a burnout with singh next to me in hoffmans… clutch got pinched down a cunt hair from it being adjusted so far off, felt the car kick so thought the tires were spinning… After about a minute it started to smoke really bad and smell like burning assholes… needless to say not my finest moment and I felt like such a jackass
Got another 2-3kmi off that clutch before it started to slip though :rofl
A link on r3vlimited led me to the trans fluid issue happening and white smoke out the exhaust. I figured since the clutch is due soon it may have gone, car has never smoked that hard before. But then found another thread that said headgasket or moisture in the air. Glad it was nothin big!
Dude the transmission is not going to make the exhaust blow white smoke. It’s 20 degrees out its probably just moisture. When I exhale white “smoke” comes out of my mouth, but it doesn’t mean my back has a slipped disc.
